radman
- December 27, 2006
- Location
- Indiana
- Camby
- 99 Eddie 5.0
Coverter Drain
What Turdle said, the converter drain can be accessed by a 1 1/4" black plastic plug right on the bottom of the converter housing. Pry it out, it just snaps in, and then unplug your wires to the coil packs so the engine does not start up while having a friend jog the starter with the key switch. You can watch the converter turn past the hole while looking for the drain plug. It may take several try's before it stops in the opening.
When draining the transfer case make sure the fill plug can be removed before draining the fluid from the case and do not be surprised if you find the transfer case over full as it is possible for transmission fluid to migrate in to it through a small vent hole between the two units.
Last thing is how difficult it is to get fluid back into the transfer case without having some kind of pump to do it. There is practically no room under there to even place a small funnel with a hose on it. I used a small oil pump can and refilled it many times until the case was replenished.
Mike
Mike
