torque converter | Ford Explorer Forums
torque converter
92302expo
Lufkin, Tx
92 Expo xlt 4x4 5.0
I picked up a "rebuilt" trans and tc a couple weeks ago that came out of 88 b2 (2.9efi) and i was wondering if the tc would work with my 4.0? or do i need to get a new tc?
It Will Work , But it will not work the same as a 4.0 TC or Trans , The BII trans and TC are designed for a lower HP motor , I know for a fact because I have a BII trans and TC In my 91 Navajo , I also don't have OD so make sure the plug on the driver side for the TCC lockup for OD is the same before You Put it in , Also the older BII Trans are missing 2 bottom bolt locations on the Bell Housing . As seen in this pic , Left is a 91-94 A4ld , Right is an 87-88 BII Trans ..
I'm guessing the tcc is this
and if it is yea its different, is there any way to make it work?
I was told you have to use 2 of the 3 wires from the stock wiring and connect them to that plug , but my OD is shot on my trans , I put it into OD and it slightly pulls then when you give it gas it does nothing at all , Must have been shot when I bought it , I tried to do with wiring to that plug and it didn't help me any .
you happen to know which 2 they are? the plug on mine has a red, orange/yellow, and purple/yellow
also three more things, first the shift lever is different on the b2 trans what should i do about that?
VS.
Second is the tc a lower stall than the 4.0 or higher stall?
Third would you recommend swapping the bell housings?
You will have to Remove and replace the shift linkage , Not hard , but not easy either ,The BII TC is a lower stall , so it takes the 4.0 More Rpm to get up to the same speed as a 4.0 TC , You could Swap bell housings , but you would need to buy new gaskets and possibly rubber O rings for the bolts , and if the 4.0 bell housing was leaking fluid , you would want to get a new TC pump bushing installed
I'll prob leave the bellhousing alone then seeing as i still have to buy tires and have the exhaust fixed. do you know of a thread that tells you how to remove the shifter link because i spent the last 2 hours trying to find one and couldn't.
I'm not fully sure on the thread to remove and replace the linkage , But I can Offer Some words of wisdom on that , There is a Metal pin going into the aluminum case that holds the shift linkage , you will have to unbolt from the inside , and Remove a small clip I do believe , Once you have both of them flipped over and looking at the linkages with the pans off , you will get a general Idea of what needs to be done
thank you for your help and words of wisdom, and did you get an alignment after you did your 2.5 skyjacker coils?
sorry for not responding yesterday , My mother passed away yesterday , I have not did an alignment after the 2" Skyjacker coils, I put 2.5" on my sig because it gave me roughly 3" of lift due to my stock coil being sagged so much , and I have heard of some people getting at least 2.5" to 3" of lift from them
hey i understand and sorry for your loss I'll keep you and your family in my prayers.
Thank you its much appreciated
