Torsion bar strengths ? | Page 2 | Ford Explorer Forums
Does anyone know if ranger torsion bars are interchangeable with Expo ones ? Anyone have any tips ?
98+ Rangers may have coil spring or torsion bar front suspension. The ones with torsion bars are interchangeable with 95~2001 Explorer.
Most torsion bar Rangers use 1, B or F. The spring code is on the manufacturer's certification sticker on the drive door jamb. You can also take a caliper to the junkard and measure the diameter:
1 = 1.09" (<- this is Ford info. FWIW, my #1 bars measure closer to 1.10")
B = 1.06"
F = 1.03"
Torsion bars are computer selected on the assembly line to match vehicle configuration and options. Obviously, the #1 bars are the thickest and have the highest spring rate - these are usually found on optioned up Ranger 4x4 Supercabs although some have B's. F bars are found on lighter Rangers such as the 2WD regular cab Edge.
It's also important to know that the left and right torsion bars are different lengths.
They make super pry/beater bars as used steel.
