Yes
The torsion bar end is a hex--or it looks like a bolt.
The "key" looks like a funny wrench
You take the
"wrench"(key) off the "bolt"( torsion bar), and move it a notch, free end 1 notch up for lower, one notch down for higher.
I would bet doing this will put you at max heighth, with adjuster bolt almost all the way out. This is an assumption--remember. try it before you drive it.
My assumption stems from a lowering thread, which I can't find now.
However, the member noticed the level stance could only be achieved with the passenger side bolt all the way in, and drive side all the way out. Even then the passenger side was lower.
He re-indexed the passenger side key, now is level with bolts nearly even.
Get it?
