Tow Weight Limit 2014 XLT | Ford Explorer - Ford Ranger Forums - Serious Explorations
geecee58
OH
2014 Explorer LXT
I have a 2014 XLT Explorer. I want to pull a travel trailer. I don't want to pull anything too heavy, but would like to find something between 2500 to 3500 lbs. dry weight. According to what I read in 2014 FORD EXPLORER TECHNICAL SPECIFICATIONS Maximum towing capacity (properly equipped) is 5000 lbs.
peterk9
Staff member
Moderator
2020 Aviator Reserve
Callsign
VE3
Welcome to the Forum. :wave:
That is correct as long as you have the factory installed class III tow package. You would also require a weight distribution hitch if going over 2000 lbs.
The towing info is also on page 280 of the Owner's Manual, 3rd pront.
geecee58
OH
2014 Explorer LXT
Thanks. I'm going to have to check on line for the owner's manual. I bought my 2014 used, and didn't notice the manual was missing until sometime later when I wanted to check something out. My Explorer doesn't have a hitch, so that will be something I'll have to have installed.
Michael Blackburn
Virginia Beach, VA
2018 Explorer Limited 4WD
With no factory hitch you are limited to 2000lbs. No matter what hitch you install.
peterk9
Staff member
Moderator
Callsign
VE3
Michael is correct. With an aftermarket hitch, you are legally limited to 2000 lbs.
as for the manual, here you go; https://www.ford.com/support/vehicle/Explorer/2014/owner-manuals/
JAPeterson
Gypsum, Co
2016 XLT
One other thing that you need to consider when looking for a trailer is that what is quoted is the dry weight of the trailer and not the loaded weight.
You also need to figure the water, propane, food, clothing, and bedding once everything is loaded into that trailer. So that trailer that you might be looking at that has a dry weight of 2500-3000 lbs will weight closer to 4,000-5,000 lbs once everything is loaded inside of it.
geecee58
OH
2014 Explorer LXT
Thanks. I think, as much as I love my Ford Explorer, when I get it paid off next year, I will probably trade it in for a Class B/B plus RV. I'm almost 70 years old, I'm entering the winter years of life, and I want to get back into seeing as much of this wonderful country as I can. I'm not worried about traveling in luxury, but I do want something that can double as my main vehicle and my home away from home. Hopefully I can find a nice used, affordable van with a Ford chassis.
JAPeterson
Gypsum, Co
2016 XLT
If I was you I would start looking now for a used trailer. Quite often as fall arrives you can find ones that people have used just a few times and realized that trailer life isn't what they thought that it should be.
Then also look for a F150 to pull it. That way you can enjoy both worlds. A trailer that you can park somewhere with a vehicle that not only can tow it but something that you don't have to take your home with you to see something. The F150's towing ratings are going up every year it seams.
geecee58
OH
2014 Explorer LXT
That's a great idea. It would be bice if I could find someone selling both together.
