dmjcmj1
- December 4, 2012
- Butler, PA.
- 2004 Explorer Limited
Hello Everyone,
I am new to the sight and have a TPMS problem I need help with. The message center on my 2004 Explorer Limited AWD said Tire Pressure Sensor Fault so I took it to my local tire dealer and had 2 bad sensors replaced. They said they programed the new sensors and everything was good to go. The first time I started my Explorer after making a stop for gas the Sensor fault was back on the message center again. I did some research and found the procedure for resetting the system but since I don't have the magnet I took the vehicle back to them to try it again. The initialization of the training procedure was followed step by step and the tpms indicator started flashing but the horn did not sound. The tech compleated the procedure but the horn did not sound signaling that the procedure was complete. The scan tool showed the corect tire pressure in each tire and the message center warning was out but after my first stop just like last time the Tire pressure Sensor Fault came back on. Any one have any ideas as to what could be happening?
