You'll need to get the sensors programmed on the car. A programming tool is pretty cheap, or you can get a dealer to do it. Note that the sensors on the newest cars (2010 and later?) are different than the band-mounted sensors used on the 2008, and not compatible.
=Vic=
Bands, much much cheaper than from Ford and reusable, too, are readily available. They are basically big pipe clamps. Look at American Muscle dot com for a source. You can reuse the module on your existing wheels or buy new ones, also at the same place. I got a whole new set...bands, modules, programming tool and even an install video on DVD for less than Ford would charge for one wheel...and these are Ford-branded modules, too!. Finally, there are now available the valve stem modules that are compatible with the original band modules.So are there no aftermarket alternatives for the TPMS3 band modules? I have sensors on the stems (I can see the fitting) that came with my 06 Explorer when I bought it, but the Tire Pressure Fault light has come on since day one for me. Is there a chance they would work and just need to be pinged?
I think Ford screwed the pooch on these stupid band modules, especially seeing that they charge over $50 for the band alone! If I can get an aftermarket stem mounted module that will be compatiable, I'd rather do that.
Amazon says this one will work, but I'm not sure I want to trust them.
http://www.amazon.com/Schrader-3300...r=2006|2006&carId=001&n=15684181&s=automotive
Anyone know?
Cheapest is to reuse your modules and just buy the new aftermarket bands and mounting holders.
=Vic=
