FYI you do not need to install the TPMS on these wheels if you do not wish to. They are only required on OEM wheels.
I went the other way. Replaced my 20's with the base model 17" steel wheels.
Much lower cost. I did install new TPMS in them through the dealer at $56.60 (CDN) per sensor. They can be had cheaper through the Internet.
It is a tire valve kit. The new Explorers don't use the banded type. I had them installed on my 17" base model Winter wheels but unfortunately the invoice doesn't give a part number. Not sure if they would be the same as the ones I have in my OEM 20's
Looking at www.fordparts.com, there appears to be only one part number 1A189. Then there is a TPMS-12 and TPMS-23. My invoice for the 17" steel wheel shows a *12*.
Don't the factory 20" polished upgrade wheels come with TPMS? I thought the EX came standard with TPMS. I had started a thread about this previously and asked the question because when I go into the MFT diagnostics screen, it shows TPMS as being "off" but when I turn the key on, it shows the light for TPMS and the manual says the EX has TPMS.
OP....are you purchasing the 20" polished wheels after the fact?
