bluevolume
- May 2, 2000
- Rochester, NY
- 2001 XLT
I posted this same question in the "under hood..." group and didn't get a response, I hope someone looking here has some info.
I'm trying to fix some nagging performance/mileage problems and I'm at the TPS right now. Using the information on this board about fine tuning your TPS, and some info in the Haynes manual, I've found something very strange.
The Haynes manual says to check the input voltage to the TPS, which is supposed to be 5.0v. I checked mine and it is 6.5v (ignition on, engine not running).
This thread:
http://www.explorerforum.com/forums/showthread.php?s=&threadid=79362&highlight=adjust+your+TPS
says that the voltage coming back from the TPS at closed TB should be ~.96v. Mine is 1.30v.
Can anyone explain this? Do the 2001 SOHC's have different specs for their TPS'? Is there some voltage regulator pack that's gone bad, or do I need a new computer? HELP!!!
If anyone here has an 01 SOHC and would check their TPS input voltage, I would really appreciate it. The info to do it is on the thread above.
Blue
This thread:
Blue
