rasouth
- July 29, 2015
- Riverside, CA
- 96 Explorer XLT 4.0 OHV
Hey guys! I am trying to track down an a/c leak. A couple months ago my a/c started blowing warm air so I went and got some R134a with UV dye and the system was blowing cold air once again. After running the engine for a while off and on through out the day until night fall, I put on my funky yellow glasses and switched on the UV light. First off I noticed I have a leaky valve cover gasket, but looking all around I could not see any glowing UV dye. I crawled all over the engine checking all the connections and hoses I could see. I crawled underneath trying for a good look at the accumulator but did not see anything glowing. Now my accumulator is original with the rubberized wrapping on it. I have read that these can rust out and cause pin holes but my question is how can you tell if there is a leak underneath the wrap? I tried scaping some of the wrap off and I get a slight glow from where I scraped but I think it is more of a reflection off the scrape marks. I was also able to look in the blower box behind glove box because I recently had to replace the blend door and did not see any glow from inside.
Would one of those leak detectors be more reliable than the UV dye?
