wramon
- April 26, 2009
- Lares Puerto Rico
- '99 xls
i rebuild my tran with a new converter, master kit with bands, filter pump bearing,direct drum, sun gear with housing, rear and center bearing. in D all shift are ok but when i put the tran in 1st or 2nd the OD light flash. i sacanned and the codes are p0705 and 0708 so i replaced the transmission range sensor circuit with a new one with the upgrade to 11 pin (p0705,0708) but still happened the same and gave me two more codes 1705 and 1704 and i dont known the meaning of these codes. please help? all selenoids are good.
