Jonboy2002
- September 22, 2012
- Lynn Ma
- 2002 explorer sport
Hey guys! So I've been trying to trouble shoot some problems with my 2002 Explorer Sport. I have been reading through some very informative threads. My car is bucking and won't dive past an idle, and the o/d off light is blinking. I thought maybe it was the 4wd selector, so I pulled the transfer case shift motor off and manually shifted the shaft into 2wd. Didn't fix my problem. I was then thinking it was the torque converter and realized that my tranny fluid was quite high. I (naively) Thought that draining the fluid from the transfer case would also drain my tranny. Clearly not the case, but the fluid was very dark and low. The transfer case just takes the same ATF as the tranny correct? Also, is there a better way to drain tranny fluid besides dropping the pan? I would like to avoid messing with the gasket etc if I could help it. Any and all info would be greatly appreciated. Thanks in advance... Cheers!
