guys,
thanks for the replies....here is what happened and what i've done/found... when we bought the epx (used) the previous owner said it used tranny fluid..no leaks, just used the fluid..after awhile we noticed a serious leak from what i thought was the rear seal.. i mean a leak so bad that you could watch the oil dripping when it was runinng.. so i removed the transfer case and the tranny.. took off the flywheel, discovered that it wasn't the seal,but the oil pan gasket.. had to pull the engine. drained the oil pan, in doing so, filled up a 10 qt drain pan, a 7.5 qt drain pan and STILL had oil in the pan when i pulled it..found NO gas or water or anti freeze in the pan....like i said, have never added oil except when changing the filter.. yes it smoked really bad, ran rough as crap.. did find fluid in the vacuum line from tranny to plenum.....I work p/t at auto zone an in talking ot those guys, everybody says it is the modualtor....gonna rebuild the v6 and the tanny.... was trying to fiure out whether i was on the right track as far as the mod goes so i guess i was?
