bennyhana20
- July 15, 2004
- Amherst, MA
- 92 explorer xlt
92 XLT automatic 4 wheel 115000 miles
in about mid august i blew my seal at the torque converter which resulted in about 5 quarts of fluid pissing out. The whole process took place going 70 on the highway at about 4 in the morning. After putting 5 quarts of ATF in the tranny it was running as pisser as ever, (only damage was about a 1-2 second delay engaging drive gears). But once the tranny had warmed up the tranny began pissing again. (fluid leak directly between engine and transmision)
with no transmission experience, but help from friends i pulled the tranny and changed the seal. This involved removing the bell housing and tapping the seal from the other side. i had some gear out which i wasn't happy about but everything seemed snug when putting back together. I made sure the torque converter was fully engaged and put back in its original position against the drive plate.
Once everything was back together i put in about 8 quarts. (Torque converter empty) and ran the engine. at this time i did not have the vaccuum hose at the vacuum diaphram attached (accidentally) the engine was idling high, the transmission engaged in reverse and drive, drive gears would not shift (i think due to vaccuum hose detached) i was driving about 30-35 mph, and slowly it slipped from gear, and wouldn't go back into drive, getting the enging high about 2-3000 rpm, i was able to get the truck moving enough to get back to my house.
At this point i located the problem with the vaccuum hose, attached it, and the tranny and engine sound perfect. I put some more fluid in ( at this point about 9 1/4- 9 1/2 quarts, but the reading is very high on dipstick.
Right now reverse engages Very Smooth, no shaking, Park engages, and neutral engages, but no drive gears engage, and car will not move forward even when reving engine high.
i played with the linkage excesssively to attempt to correct the problem. linkage arm seemed to get knocked around when dropping tranny.
Any ideas for me, im praying its something simple. Something that does not involve pulling that tranny off again.
My one concern is a gear that fell out when i had the bell housing off. it was about 5 inches in diameter. one side had a 45 degree angled notch on one section on one side, i am pretty sure i put it back correctly, it spun smoothly and there was no marks or evident necessity for the angled notch facing one particular direcion. This is basically my only concern..
i hope my problem is a linkage issue. please get back to me... thanks a ****load!!!!!!!
