No... unless your OHV is 98-2000
The OHV had a 6 bolt crank until 1998 when it switched to a 8 bolt crank (same as SOHC)
So the 90-97 OHV has 6 bolt crank and flywheel.
For those we simply pull the locating dowels from the flywheel, lay the new SOHC clutch on there with alignment tool, mark center punch, drill/tap thread 6 new clutch hold down bolts.
The clutch is like 10.5" driven disc vs the old 9.5" driven disc (or something like that) The 03+ SOHC clutch pressure plate has dual springs/upgrades that give the old ohv a much much better grip and clutch performance, pedal feel is far superior IMO
Can have your favorite machine shop do the work for you usually under $100.
With the 98-2000 OHV's you can just use the SOHC 8 bolt flywheel yes.
You still use the OHV throw-out bearing, slave and master cylinder
This is the clutch I always order
$150 not bad, few years ago these were like almost $300
