Alsmarineparts
- September 28, 2011
- New Jersey
- 1997 Ford Explorer XLT
Ok I changed all the solenoids in trans and the one on t/c and rear diff. Still same. The (ABS) light is on all the time and has been since I got it on the road.
This is what happens. When driving for about 15 mins It starts to not shift on time rpm at 3100 then shifts and if I take off the gas then step again it races a little. If I shift manual it works. I am a certified deisel mechanic but this is entirely different. Is the (ABS) for the brakes ? And will it effect the trans operation. If so where is it. I got a code on my auto xray it was 500 which is vss and 1506 which is idle control. This is a 97 4.0 sohc, 5r55e with a 4405
T/C Any help would be great. Also the speedo most of the time does not work and when it does it jumps.
