86capriasc
- September 19, 2009
- Wisconsin
- 1998 Explorer XLT
I have a 98 SOHC Explorer. The trans is slipping in all gears, to the point that it will barely move in any gear. But I do have reverse and forward gears but it takes a lot to get it moving.
From what I know, my wife drove it to work the other night and said the O/D light was flashing but eventually stopped. She works 30 miles away and that night she had to go to different store that is also 30 miles away. So in all she put on 120 miles that night total after the flashing O/D light problem. I went to drive it yesterday and it seemed fine for the first 1/2 mile. Then it wouldn't shift right, I was running 2500rpm at 40 mph. I stopped right away and tried to turn around but it would barely move in reverse unless I gave it a lot of gas. After making it back home the first thing I did was check the fluid level which was fine but I did it does smell slightly burnt. Oh by the way the truck has 178k miles on it and I did a filter and fluid change last summer. Anyway this is her transportation to and from work and we are now down to one vehicle.
So where should I start to look? I have been reading and reading many post on here about different issues with these transmissions. A lot of good article but after reading so many I'm still not sure what I should start with. I am very mechanically inclined and have only ever taken vehicles in to have auto trannys rebuilt. I thing I would like to give this a shot if that is what is needed. But before I go pulling it I would like to figure out if is something else. I tried to pull the codes with my obd II scanner but came up with nothing.
And if it comes down to a rebuild what if any specialty tools would I need to perform this correctly.
Thanks in advance for any advice.
Mike
Mike
