Transfer case fluid- 95 explorer xlt | Ford Explorer Forums
Pete Deering
New England
1995 xlt 4 door 4x4
Change my transmission fluid the other day with MERCON V. On the Val bottle there was a tech support number so I call it and ask the tech support, can MERCON V be used in transfer case He answer YES, and also MAXLIFE.
Ford says no. You do you, but I keep V away from my transfer cases.
No, you cannot use Mercon V in the t case. Use Dextron III equivalent.
As others have stated on transfer case is correct. This is what I used on my 95 / Same TC:
