Chris Harrach
- May 6, 2010
- Atlanta, Ga.
- '97 Eddie Bauer 4WD
Ive been dealing with a bad Borg Warner 4405 TC since July, and Im about to replace it. However, in the last 3 weeks or so I noticed that I no longer seem to have Overdrive. The dash light doesnt come on and depressing the O/D on off button on the shifter doesnt do anything.
Also, Ive had a few instances where Reverse won't engage (which produces a sort of grinding/whirring sound similar to the bad Transfer case) as well as park. This is usually overcome by putting it in drive & driving forward for a few minutes, after which, everything goes back to normal. There's never any warning for this which makes parking a challenge.
Now for the BIG QUETIONS:
1. Will the upcoming replacement of the bad Transfer Case resolve these problems? Im sure it has a lot to do with it.
2. Will replacing the various sensor on the Transmission solve the problem?(Speed sensor & Overdrive sensor first come to mind)
3. Should I just replace the Transmission along with the Transfer Case???
Any thoughts and advise would be greatly appreciated. Thanks in advance.
Chris Harrach
Chris Harrach
