Transfer case | Ford Explorer Forums
Transfer case
Beverley
Point
97 explorer
Trying to help my son figure out why his 97's transfer case is stuck in neutral
Bev can you offer more information? A better description and chain of events.
I didn't know Explorers had neutral, have you tried 4WD low? I know in some cases, the case will fail and act like neutral except in 4-Low
He said he will be driving down the road and it will slip into neutral generally he could get it back in gear but now it is stuck
Bev it sounds like the range slider is slipping out of engagement (you will hear a buzzing or grinding noise if this is the case). Rebuild it if you can, and do the upgrades while you are in there. And I absolutely agree with RandomNerd, that is the sign of a failing T-Case for sure if you can get LOW range but not HIGH.
