Biniecki
- December 9, 2013
- 1996 Ford Explorer
I have a 96 Explorer Sport 4x4 with a 4.0L. I noticed a little bit of trans fluid dripping from under the front of the vehicle. It appears to be coming from the trans cooler lines that have started to rust out. When looking up the parts I came across a couple different part numbers.
7A030 - Trans Cooler Inlet Hose - Runs from trans to cooler
7A031 - Trans Cooler Outlet Hose - Runs from upper left of radiator to trans
7C410 - Trans Cooler Hose - Runs from cooler to lower left of radiator
My concern is that these numbers specify that they are for vehicles with the 5.0L engine and not the 4.0L. Will these parts still work or do I need different ones? I have noticed some vendors will add additional letters to the end such as AA, AB, C, LA and have no idea what they mean. Can someone point me in the right direction of which parts I need. Thanks
