Transmission Fill Tube Replacement | Ford Explorer Forums
kleachy
Madison, IN
2000 Explorer Limited
Looking for a replacement Transmission fill tube for a 5.0/4r70w combination. Seems most are 5.4/4r70w instead of 5.0. Appears they are different. Anyone have a part number or source to replace? I do want stock. Thanks!!
Apparently according to the parts websites I can find. the 5.0 Trans dipstick tube is the same for the 4.0 sohc? @410Fortune can you confirm?
New Genuine Ford Transmission Oil Filler Tube (1997-2003) OE F77Z7A228AA
Thank you for your response. Looking at the diagram, the mounting flange is different. That has been the issue but I may have to order and see if it will fit. You know how some illustrations are not exact. Thanks again!
I would try the junk yard, These come off of the 4.0 sohcs pretty easy. they have a single nut under the heater hoses on right front of the engine. then just twist it a little bit back and forth and pull. should come right out.
