Hi All, I recently purchased a 1997 ford explorer 4wd (UK) 4.0 SOHC it's in amazing condition for 25 years old I am only the third owner.
It has only covered 22,000 miles.
Anyway I am going through maintenance jobs on it, recently changed the intake manifold gaskets due to rough start, oil change plugs and leads etc.
I just purchased Mercon V fluid for a transmission fluid change and was thinking of pumping out from front cooler and replacing through dipstick filler until all fluid changed, my reason for this method is my Cat is under the pan and have read how awkward it is to remove.
I would be changing on my driveway with ramps so not great clearance, I have no leaks or gear change issues.
So looking for some feedback / thoughts as it's only extremely low mileage an fluid looks clean on dipstick and smells good
Do I just change fluid for now and then filter if still own at 50,000 miles.
Also will the Mercon V be okay in my power steering?
Thanks Darren
