Ted20
- February 23, 2023
- Anaheim, Ca
- 2007 Ford Explorer 4.0 2W
I have 2007 Explorer 4.0 2WD 5r55s transmission that works weird recently.
I've got transmission line popped out last month and lots of fluid came out. They fixed the line and filled the fluid. They explained it was a bad trans radiator. But after the repair I noticed the transmission started to hesitated a bit on cold when switched from P position. And then eventually it stopped doing anything at all on cold unless I rev up and probably build some pressure in the transmission. After that I can drive and the transmission works perfectly fine. But if I turn off the engine and wait 5 minutes, then I have to rev up all over again to make transmission work.
Any idea what could it be and if there could be an easy fix?
