Transmission problems. | Ford Explorer Forums
B011
1995 2wd explorer XLT
Hello everyone,
I am a new member and would like to ask a few questions about my 95' Explorer. I am having the flashing o/d light issue that seems to be common in Explorers. While shifting from 1st to 2nd( it is a automatic),you have to let off the gas to allow it to shift. It shifts normally thru the other gears. My other issue is that it did not pass smog due to the PPM measuring too high. I was told that it was running too rich. Any ideas on what I can check to fix these problems?
Welcome to this forum! I've moved your thread into the transmissions section. It sounds like you have a broken band. You should find out what the trouble code numbers are before you invest any money on parts.
