natedoggaz
- October 15, 2008
- 2002 Explorer
Hello all, I haven't posted in a while so I hope you are all well!
2002 4.6 Explorer
Last project I completed was changing out the moog springs on the front end with the Struttek struts...
Anyways, I have been noticing this issue for a while now, only happens ever so often and thought it went away - but unfortunately no...
When driving at certain speeds and locked into gear, if the accelerator is pushed down and the trans shifts to a better gear, it seems like it gets "stuck" between gears and this back-and-forth rocking occurs.
It will occur until you take your foot off the gas and I guess it slips into gear, and then it drives fine.
I was told by a Ford guy that it may be an issue with the #6 cylinder. So I went and replaced the boot and pack on plug. I did not experience it for a long while, then it started happening again.
It started to idle a little rough, so I took it in and mechanic said #8 had a misfire. So I replaced the boot and coli on #8 - as well as ALL the plugs.
Its still idling rough, and the back-and-forth rocking is still occurring!
I know this is a lot of info - but hopefully enough...
Anyone have ideas?
BTW I cleaned the MAF sensor and that did pretty much nothing...
Thanks!
ND
2002 4.6 Explorer
Anyone have ideas?
Thanks!
ND
