Transmission Slipping in 3rd. | Ford Explorer Forums
A1C_Snowman
Elmendorf AFB, AK
2002 XLT 4x4
Ok so I went out ruckusing tonight, and was climbing a pretty steep and rutty hill. A couple of times I lost traction in the rear, but I punched it to try and get the fronts to pull me up. I finally got up the hill, but then I noticed some smoke coming from the tranny area. Now my 3rd gear is shot. All other gears are fine. My truck shifts normal 1st to 2nd, but once it hits 3 it shoots right up the RPM band. If I lift the throttle it will shift to 4th and continue on it merry way just like normal. I also noticed that after it slipped my O/D lift flashed rapidly. Please tell me I didn't grenade my tranny. If you think that adjusting the band and changing the fluid might help let me know. Also if you can think of anything else let me know.
I'm guess I have to find someone with a scanner then. You think somewhere like NAPA would have a scanner.
meh no Autozone up here in Alaska. Hopefully Napa or Carquest have one.
Go to Schucks. I had the same problem today and went into Schucks and got it scanned for free. My Pcode was P0745. Some transmission sensor.
