Jones
- April 23, 2005
- Minneapolis Minnesota
- 94 XLT
Jones
94 Explorer XLT
My A4LD is giving me fits. It will not upshift correctly in any gear except OD, and vacuum downshifts into too low a gear for added redline entertainment. I thought it was the speed governer as these are apparently problematic, and I decided to ignore the fact that everyone says the governer controls only first to second shift and maybe OD, and second to third is by far my worst shift and OD my only good one. I took down the tranfer case (which had a bad seal and almost no fluid) and the governer was stuck, had burrs on it, and that part of the case had a lot of pretty good sized grit in it. Well, that's that I thought, and after doing the neccessary and changing the tranny fluid and filter and so on, I happily bolted it back together and patted myself on the back for a job well done.
Until the test drive, when the problem persisted, a little worse if anything, but with all the gears locking up great, and pulling better than ever. Every gear seems as strong as could be. So I wonder if this is a blockage somewhere in the valve body of the tranny, and if that means a soft rebuild, or if there is any possible way (Oh please, oh please) that the vacum solenoid could somehow be communicating an excess of vacuum by being stuck, thereby causing the truck to think it is accelerating hard. In order to get it to shift, you have to run the revs up to around 4300 and slowly, gently ease back on the throttle until it gears in, then even more slowly and gently come back onto it to accelerate up. About two times out of three at this point it drops back into the lower gear, and i throw something out of the window. If anyone has any ideas i would be grateful in the extreme.
Thanks In Advance,
Jones
94 Explorer XLT
Thanks In Advance,
Jones
