Davidzetterlund
- June 13, 2015
- Stockholm
- Ford explorer 2002
I follow this step:
• Insert a key in the ignition and turn from 1 (LOCK) to 3 (ON) and cycle between 1 (LOCK) and 3 (ON) eight times in rapid succession (within 10 seconds) with the eighth turn ending in the 3 (ON) position. The doors will lock/unlock to confirm that programming mode has been entered.
• Within 20 seconds, program a remote transmitter by pressing any button on a transmitter. The doors will lock/unlock to confirm that the remote transmitter has been programmed. (If more than 20 seconds pass before pressing a remote transmitter button, the programming mode will exit and the procedure will have to be repeated.)
• Repeat the previous step to program additional remote transmitters. The doors will lock/unlock to confirm that each remote transmitter has been programmed.
• When you have completed programming the remote transmitters, turn the ignition to 1 (LOCK) or wait 20 seconds. Again the doors will lock/unlock to confirm programming has been completed.
I did this yesterday with a new transmitter, worked great.
But when i tried to unlock the car today, none of the transmitter works. Even the old is not working now.
Tried to do the programig today again, but when i push a button after turn on/of, nothing happens. I've tried like 20 times whit both transmitters and differenk keys in the lock.
This drive me crasy. Suck to not be able to use the transmitters.
Any tips please
Any tips please
