Trouble bleeding brakes | Ford Explorer Forums
Timothy Gray
Wapakoneta
2003 explorer sportrac
I changed the front calipers and I cannot get any pedal after I bled them
I even changed the mastr cylinder I have pedal when the engine is off
But when the engine is running no pedal I bench bled the new cailiper and
Then used the bleeder to bleed the m/cyl still no pedal when I changed the calipers I let the fluid get too low I thnk that is where the trouble started but I changed the m/ cyl t should have taken care of problem
I welcome any help
Nhak
Once you've gotten air in the ABS system it is very difficult to bleed the brakes. The ABS system has a pump that I believe has to be made to run to get the air out.
