adctp13
- July 18, 2014
- tacoma washington
- 93 ford explorer xlt
hello my name is alex...i have a stock 93 ford explorer xlt my transmisson went out or so i thought went to the junk yard pulled another replace the bad wit the used and ended with the same result, i then replaced the t.c. ended up in the same spot. so a friend of mine mentioned the transfercase...i was under the impression that the transfluid flowed threw the trans to the transfer case so when i reatached my transfercase to the transmission originaly when i first changed the trans out i did not fill the transfercase...is this the root of my problem? if so remedies please...i appricate the time taken to read my post n await yourr responses.
