Nifty
- November 20, 2006
- Twin Cities, Mn
- 99 Mercury Mountaineer
Hi guys,
Your board has been very helpful in past fixing various issues with my truck. In the last two weeks Ive run into a problem starting my 4.0l mountaineer. I start the truck and I can hear the pump cycle, it cranks and sounds fine. Sometimes it starts but dies almost immediately. But most of the time it cranks but won't start. The only way I'm able to get it to start when it does this is to act as if its flooded and push the accelerator all the way to the floor and then it will start. Occasionally when it starts this way I will have to hit the gas a couple of times or it will die again.
I did a little reading on here and bought a coolant temp. sensor but it has been -11 here since I bought it and I haven't had a chance to put it in. Are there any other areas that you guys think I should look at.
