Trying to Find a Part Number for Trunk Storage Compartment Panel
atomiczach
2014 Explorer Base
Hello all, I am new here so I apologize if I am breaking any rule. I am trying to find a part number for the part in the picture. This is driving me nuts. I am looking for a replacement so that, being the nerd I am, I can repurpose this compartment for a cellular hotspot, vehicle tracker, computers and such. 2014 Explorer Base
peterk9
Staff member
Moderator
Ottawa, Ontario area
2020 Aviator Reserve
Callsign
VE3
Welcome to the Forum.:wave:
As mshields422 mentioned, it appears that the compartment may be part of the entire side trim panel. If you look inside the compartment you could probably tell if it is a moulded part or a separate feature.
T 2013 Power liftgate has been trying to eat me Stock 2011 - 2019 Ford Explorer Discussion 0
A Trying not to be angry dealing with Ford Customer Service... Stock 2011 - 2019 Ford Explorer Discussion 45
A Trying to get an idea Stock 2011 - 2019 Ford Explorer Discussion 3
M Two horn honks. What is it trying to tell me? Stock 2011 - 2019 Ford Explorer Discussion 3
M Trying to install LED lights Stock 2011 - 2019 Ford Explorer Discussion 2
L Sync Problems when trying to play music Stock 2011 - 2019 Ford Explorer Discussion 4
chimoman Error Message when trying to update on Sync Site Stock 2011 - 2019 Ford Explorer Discussion 3
R 2019 Limited radio won't find FM stations well Stock 2011 - 2019 Ford Explorer Discussion 5
R Need Help With Part Name and Where to Find a Replacement Stock 2011 - 2019 Ford Explorer Discussion 2
M Front axle seal is leaking ... can't find part Stock 2011 - 2019 Ford Explorer Discussion 16
B Looking for to find info on tires for my 2014 Explorer Sport Stock 2011 - 2019 Ford Explorer Discussion 3
J Find door lock code on 17 Explorer? Stock 2011 - 2019 Ford Explorer Discussion 9
Daheim111 Amount of engine emission / where to find exact values ? Stock 2011 - 2019 Ford Explorer Discussion 2
D Right headlight won't work, can't find fuse? Stock 2011 - 2019 Ford Explorer Discussion 13
O hard to find ford part 29164 Stock 2011 - 2019 Ford Explorer Discussion 3
S 2015 Explorer Sport fog light wiring plug, cant find location Stock 2011 - 2019 Ford Explorer Discussion 1
D Anyone able to find an A/C Compressor Clutch? Stock 2011 - 2019 Ford Explorer Discussion 4
P Anyone know of where to find a diagram of the 3.5L TT engine in the sport? Stock 2011 - 2019 Ford Explorer Discussion 2
D Why are 2nd row bucket seats so hard to find? Stock 2011 - 2019 Ford Explorer Discussion 33
G Where to find replacement headlight dust/moisture caps? Stock 2011 - 2019 Ford Explorer Discussion 2
1 Good place to find TSBs and information Stock 2011 - 2019 Ford Explorer Discussion 3
H PLEASE help. Todqy got '13 explorer and cannot find 12 v outlets to charge phone, nav Stock 2011 - 2019 Ford Explorer Discussion 11
C Can't find a sport Stock 2011 - 2019 Ford Explorer Discussion 16
J Find My Son Listening To Radio While I'm Out of Vehicle With Keys ? Stock 2011 - 2019 Ford Explorer Discussion 5
RonJrSVCMGR Is it just me or do all of you find.... Stock 2011 - 2019 Ford Explorer Discussion 13
R Navigation cant find city without address, what? Stock 2011 - 2019 Ford Explorer Discussion 3
J Can't find this feature Stock 2011 - 2019 Ford Explorer Discussion 1
C Does any 1 know how to find out when sync waz installed Stock 2011 - 2019 Ford Explorer Discussion 9
H how to find snyc version? Stock 2011 - 2019 Ford Explorer Discussion 5
S Where to find the Explorer owner's manual in pdf? Stock 2011 - 2019 Ford Explorer Discussion 15
R Liftgate backup camera trim/housing with washer part numbers Stock 2011 - 2019 Ford Explorer Discussion 3
R Help finding correct part number....... (Heated seat) Stock 2011 - 2019 Ford Explorer Discussion 5
E Headlight connector part # Stock 2011 - 2019 Ford Explorer Discussion 7
T Anyone got a part number for a single horn (Low Tone) '16 Ex LTD Stock 2011 - 2019 Ford Explorer Discussion 2
D ball joint part number Stock 2011 - 2019 Ford Explorer Discussion 7
T 2017 Explorer Push Retainer Bumper Part Stock 2011 - 2019 Ford Explorer Discussion 3
M 2016 Explorer Sport Tail Light Part? Stock 2011 - 2019 Ford Explorer Discussion 3
G Part help - 2013 explorer sport Stock 2011 - 2019 Ford Explorer Discussion 3
G Foglight bulb access cover part number? Stock 2011 - 2019 Ford Explorer Discussion 4
B 2014 Explorer - EATC Module location & part number? Stock 2011 - 2019 Ford Explorer Discussion 1
H Front right Axle Assembly part # for 2011 explorer base model Stock 2011 - 2019 Ford Explorer Discussion 34
2 Rectangular part missing from inside of liftgate Stock 2011 - 2019 Ford Explorer Discussion 3
P Rubber below windshield damaged, replacement part? Stock 2011 - 2019 Ford Explorer Discussion 2
S Need console piece part number Stock 2011 - 2019 Ford Explorer Discussion 3
Rainlord What is this light called, and what's the part #? Stock 2011 - 2019 Ford Explorer Discussion 7
Ron Bumpus Part Number help Stock 2011 - 2019 Ford Explorer Discussion 5
1 Mystery part... Stock 2011 - 2019 Ford Explorer Discussion 2
B Confusion on front upper strut bracket part numbers - 2012 Stock 2011 - 2019 Ford Explorer Discussion 7
Daheim111 Steering wheel noise...only from the upper part of the column ? Stock 2011 - 2019 Ford Explorer Discussion 6
Rainlord Looking for a hex screw/bolt part number Stock 2011 - 2019 Ford Explorer Discussion 10
Similar threads
