lexplorer
- July 24, 2002
- burlington ontario,canada
- '92 XLT
I found a new noise the last couple of days ,it started off with a squealing noise like something rubbing against metal going in circle(best way to describe)Just from starting position. Heavy vibration during driving ,, I would put it in N and the vibrationg would stop . I lifted up the rear end and the tires seem to move quite a bit . when i go into reverse and forward I do hear a clunk . To me it seems that there is to much play in the axle and I thought if the rear end was going you hear a whining sound as the gears are grinding or such. I looked at the u joints and they seem to be o.k. but could it be that it is locked and not falling out yet.. Should I just start with u joints first and what should I investigate next or does it sound like u joints ,, This is scrap yard do or die now ,because I will not replace axle as it is at its latter part of life .This has been a great truck with very minor repairs and would hate to see it go this way , Need to keep this truck going for at least another year .Thanks for help or suggestions on what to think or diagnose the problem ..
