Ronin8002
- March 23, 2003
- Virginia
- 2008 XLT Ironman
I decided to use someone's idea on this board of measuring underhood temps with a digital thermometer with a remote sensor wire. I placed the sensor on the left side of the engine (looking at it from the front of the truck) and toward the firewall.... just about 6 inches to the right of my KKM intake. I know at least one other person has done this before...but I thought maybe someone would want to see my results. Ambient air temp was 73-74 degrees for this test
Time /Underhood air temp
Cold engine 71.6
Engine running 73.6
For 1 min
2 mins 73.8
3 mins 74.8
4 mins 75.9
5 mins 77.7
6 mins 80.2
7 mins 82.6
8 mins 84.0
9 mins 85.1
10 mins 93.2
11 mins 96.1
12 mins 99.7
13 mins 103.3
14 mins 110.5
15 mins 112.8
I then backed out of the driveway and drove a mile through the neighborhood at speeds varying from 15-25 mph. After that mile underhood air temp was at 118….though it got as high as 120 at one point.
Then I got on the highway….at speeds of 45-55 mph I was seeing temps in the 110-114 range.
After that, I got on the open highway and at speeds of 65+…was seeing underhood air temps of 100-104.
I don’t know if this was a very accurate means of measuring intake air temp, but since the sensor was so close to my KKM, I think it’s safe to assume that my intake air temp was at least close to these numbers…maybe a bit higher because the air tube goes so close to the radiator.
Also, I had removed my underhood insulation before doing this test...I was looking for good places to install some hood louvres. If I get some hood louvres and then install my ceramic coated headers I'll run another test....hopefully these two mods can lower the underhood temp by as much as 10 degrees....maybe more.
Cold engine 71.6
Engine running 73.6
For 1 min
2 mins 73.8
3 mins 74.8
4 mins 75.9
5 mins 77.7
6 mins 80.2
7 mins 82.6
8 mins 84.0
9 mins 85.1
10 mins 93.2
11 mins 96.1
12 mins 99.7
13 mins 103.3
14 mins 110.5
15 mins 112.8
