Hey Rocket could we get a link to some of your engine bay pics you've had during your various stages
Scotty
all i can say is THAT IS FREAKIN AWESOME!!!!
im still fighting with the bids on ebay so far, but if that falls through im going to go ahead and look for a serries 4 from a dealer... so i should handle 8-10 psi pretty safely at almost 100K miles? thats good to hear. I just picked up a set of roller rockers(1.6, self adjusting), a 70MM BBK throttle body, a GMS lower plenum(will have to go when i go FI i assume), and a typhoon manifold(stripped a brass thread piece out of my stocker and couldnt get my coil to stay put so...). Im thinking about going to a set of patriot heads that will be less likely to shoot plugs as well as improveing HP.
but not to hijack, Does anyone know what that peice does?
yes i did, and i actualy already had to modify the mustang plenum i bought FOR the break booster line(which is the black metalic pipe above that pice). this IS coolant(i know because it spilled all over my engine when i took them off..). its just a water jacket and the line leads back down behind the engine and heads back to other plumbing pipes., and im sure it will work with out it, im just kinda curious as to what its for.
well i went ahead and spliced the pipes, and the engine seems happy enough. I have also sucsessfuly added my new plenum into the engine witch required some mods for the brake booster, and i had to kill the mounting braket for the engine dress-up cowl.(ill upload some pics if requested). I dont think ill need to have that egr system removed for awhile yet (i still have to pass IM's atm untill i get myself another set of wheels to ride while this one is cleared for seasonal only use. will the EGR getting hot be a problem ontop of my new manifold(alum)? I have thought of a few solutions if the EGR realy gets that hot.
Nothing... it is just a piece of plastic. However, supposedly when peeling that cracked piece off, the glass above tends to explode... which is never a good sign.
I have been debating whether to attempt to replace it myself.. as I can get the plastic panel for about $90.
