markfothebeast
- August 16, 2011
- St. Paul, Minnesota
- 1995 Pontiac Trans Am
I am replacing all the ball joints. I was finally able to login. I read the forum a lot. Passengers side has a goofy adjustable UCA. It looks like the ball joint has been in there since the vehicle rolled off the assembly line. I wasn't able to remove the ball joint with maximum force on a 12 ton press and beating it with a hammer while under pressure. I cut the ball out and broke the plastic out. All that is left is the metal housing. Had it under a propane torch for 20 minutes and no luck. It almost looks as if it is one with the UCA as if it was welded in. I could try a O2/MAP torch I guess. Or possibly even use a sawzall to cut it inside. Might need to go get a junkyard replacement as a last option. Any ideas?
I also have another question: How do I line up the UCA on the drivers side so that the ball joint tip sits in the knuckle of the spindle far enough so that the bolt slides in? The bolt hits the ball joint tip and won't slide through. I have the LCA jacked up but it doesn't seem like it wants to move up far enough to attach the upper ball joint. Do i have to remove the sway bar link?
