- February 8, 1999
- Wayoutin, Aridzona
- '93 XL '20 ST
- Callsign
- AB7FH
Axles
How To: Replacing Front Hub / Bearing 1995+ Ford Explorer IFS
How to: CV Axle Replacement with pictures
How to: Re-boot CV axle
How to: Replace Driveshaft CV joint
Body
How to: Open hood without cable - Help! Hood won't open!
Brakes
Great and easy way to remove stuck rotors
Chassis
How to: Parking Brake Removal and Installation with pictures
R&R 1995+ Ford Explorer Front Chassis Components: Step-by-Step Balljoints Brakes Etc
Lower Ball Joint Replacement How To with Pictures
How to: Upper Control Arm / Ball Joint Replacement with pictures
Inner Tie Rod Removal and Replacement with Photos
Sway Bar Bushing Replacement
Loose Steering
Tighten your caliper bracket bolts
CV Joints
How to: Replace Driveshaft CV joint 2nd gen
Driveline
Caution! AWD Front Driveshaft Removal - Drifts in Park
Electrical
Fuse and relay locations--2nd generation power distribution box Layout-
ford manufacturer specific codes
Engine
How to: Clean a MAF sensor
Check Engine P0340
Helpful thread, for squeak, squeal, chirp noise from under hood, engine compartment
Correct part numbers 4.0 SOHC guides & tensioners with pics...
96 V8 Explorer -Removing broken spark plug with photos
PCV Valve Sea Foam and Tuneup for 1999 Explorer 302 AWD
1997-01 v-8 5.0 ticking noise under load - EGR Tube identification-part number
How To: Replace Gaskets On The 4.0 OHV Oil Filter Adapter / Mount
Fuel System
Fuel Pump . Fuel Tank Tips and Warnings
HVAC - Engine Cooling
Heater Core Replacement - The Missing Steps
How to: Replace A/C compressor 1996 5.0
95-01 ford explorer blend door quick fix (5 minutes)
How to: Remove and Replace your 2nd gen 1996 - 2001 Explorer V8 Radiator (with pics)
Check your fan for cracks
How to: Replace thermostat 1996 4.0 OHV
How to: Replace a thermostat on a 2000 4.0L SOHC V6
In Vehicle Technology / Interior
How to: Replace Ignition Cylinder Lock
All you need to know about keyless entry
Overhead Console Display Fix
Door Ajar - Interior Lights
Radio / Clock display problem 1998 and up Explorers ( blank / fade / blanks / fades )
How to: Remove dash 2nd gen Explorer
Locating the Remote Keypad Code on a Sport
How to: Fix Power Windows 2nd gen
How to refurbish a 1998 Dimmer Switch
Replacing clutch pedal assembly
Other members useful threads and videos
2000StreetRod's Helpful threads for the 2nd Gen Explorer
JLSparky's How To Videos
Body
Brakes
Chassis
Loose Steering
CV Joints
Driveline
Electrical
Engine
Check Engine P0340
Fuel System
