Centaurus5.0
- April 15, 2016
- 96'
I'd guess 90% of 4R's failure are due to overheating from never changing the fluid (ie..break down of the AFT's friction properties) or towing in OD (extreme heat generated from the band engaging/disengaging repeatedly under load). The overheating cause clutches to burn (which shows itself as "dirty" fluid) and seals to become brittle and break. There is also early design flaws like excess wear in the accumulator piston bores (96-97) and OD servo bore and the like but symptoms like delayed shifting will show themselves well before a catastrophic failure. A side effect of this is the metal particles from the wear build up in the cooler, lines, passages, solenoids and increase wear everywhere in the trans, but still a 4R can go along time even under these conditions. The other problem, like with anything else, spring from oversight in quality control. Sometimes retainers just snap, welds give out or parts get fatigued from poor tolerances and sloppy manufacturing. In this case, there would be no signs in the fluid or funky shift behavior foretelling an impending doom.
Basic things I'm sure us all here already know. I'm just thinking out loud.
::edit::
Adding to what Don said, with your rig having well over 200,000 and if you're unsure if the cooler has ever been replaced, I'd go with a new cooler and "hose" the lines out, making sure no debris is left in them. Removing the radiator routing all together may also be a good idea.
::edit::
