Mercury93
- January 18, 2016
- West Virginia
- 2002 Explorer Limited
Problem child is a 2002 Explorer Limited, 4.6L. In cold temps such as this morning (10 degrees F), I have a hell of a time getting the car going. It has classic symptoms of a vacuum leak. Very rough idle, no throttle response (engine nearly dies when I press the throttle with it in park) and it just runs like crap. While this is happening, my ABS light turns on and stays on solid. However, once the engine gets a little warm (coolant temp needle just starts to register heat), the vac leak must seal itself because idle smooths out and it runs fine. I can also restart the car that that point and the ABS light is extinguished. I'm left wondering how a vacuum leak would affect the ABS system.
Sitting in the office at work right now and wondering if anyone had any ideas before I freeze outside trying to find the leak after work. Thanks!
