vacuum lines broke off | Ford Explorer Forums
VirtualExplorer
Toronto, Canada
1991 Explorer XLT
I was changing the oil and tuning up the engine when i rub up against the vacuum lines and they broke off from the manifold above the PVC valve
there is a set off lines coming off of the throdle body next to the brake boster that crumbled because the plastic was hard.
i know one goes to the air filter the rest im clueless
i need to now the name of the wires(part) so i can order them
help...
the factory plastic lines are notorious for this and I hate them :)
All of my vacuum hoses are now good ol rubber vacuum line from your local auto parts place.
Sonce you have a 92 Ex I can tell you where they go, from the vacuum tree on the back of the OHV 4.0L upper intake (manifold vacuum this is called):
1 goes to the fuel pressure regulator
1 goes to the airbox, vacuum canister, also branches off and goes to the vacuum solenoid inside the cab for the heater controls
1 goes to the cruise control canister
1 big one goes to the brake booster
1 goes to the EGR valve (if equipped)
if you have an automatic 1 also gos to the A4LD vacuum solenoid.
I think thats all of them?
Dont be afraid to use regular rubber vacuum hose and T's available at most auto parts places.
I can get the lines but what about the ends that conect to the manifold. the rubber piece is also cracked and needs replacement
I dont understand, rubber hose will fit over the metal tree fittings.
You just need to get the right size.
What fitting are you talking about?
I have used rubber hose OVER the plastic lines as well to make up short sections. be creative.
do you know what sizes i should be looking for??
not off hand, I just pick by looking You will need different sizes.
Heck I have used clear aquarium air pump line to patch a broken plastic line too, so just be creative, get a variety, there are only like 3 sizes of vacuum line.
You can also use windshield washer line
Junk yards are a great source for these materials also
