WaltZ
- December 21, 2011
- Port Byron, IL
- 2006 Mercury Mountaineer
Current miles: 170,000
When the speedo hits 55mph, there is a very noticeable vibration and noise throughout the vehicle. This only happens when I press the gas pedal. If I take my foot off, the vibration goes away, no matter what speed I’m at. Once I get past 75mph, the vibration is very subtle, but still present.
I had the local former Mercury dealer replace the front wheel bearing (it needed to be replaced anyway) and I had them change the tranny fluid (it’s never been done). They lifted the vehicle and ran up past 55mph. The tech ran a stethoscope and thinks the bearing in the transfer case is bad. The fluid was burnt. They replaced the fluid and nothing has changed. They also recommended a new front axle. They said I can go out and get used parts (eBay) and they will install.
I’ve seen similar issues with Explorers, but their T-cases are different than the Mounty.
Anyone else here with a Mounty had a similar issue? From what I’ve been reading with the Explorer, it could possibly be just a bad u-joint. I hate to start spit-balling parts at it.
