VSS help | Ford Explorer Forums
VSS help
Earljr
Palmdale
1999 4.o V6
I have a 1963 ford ranchero with a 1999 explorer 4.0V6 sohc and a 5R55E trans.
I inherited this from my Dad so all this info is from info he had on engine and trans, but fairly accurate.
I am at a final step in process and need to locate the VSS signal for converter I bought (so we can use the original speedo). I have the connections (they are accessible in the dash) for the explorer instrument cluster. Can I locate the signal wire at the pin? any help? thanks, Jim
