2000StreetRod
Moderator Emeritus
- May 26, 2009
- Greenville, SC
- 00 Sport FI, 03 Ltd V8
Cat catagories
In researching catalytic converters on the internet I've learned that there are multiple categories available: racing, off-road, OBDI, OBDII and CARB. Only CARB certified cats can be sold to addresses in California and are basically equivalent to the OEM unit. CARB certifcation is the strictest for emission control. Racing and off-road cats apparently have no emission control requirements. OBDI cats have no post-cat O2 sensor to monitor the effeciency of the cat. OBDII cats have a post-cat O2 sensor to determine when a cat loses it's emission effectiveness.
Ceramic substrate cats are as effective as metallic substrate cats and less expensive to manufacture. However, ceramic substrate cats are slightly more restrictive and more temperature sensitive than metallic subtrate cats. Metallic substrate cats are more desireable for high performance engines (especially forced induction) which often operate at richer air/fuel ratios resulting is higher cat temperatures.
Here in South Carolina we have no annual emission inspections and I could probably install a racing cat on my Sport if I did it myself. However, eventually there may be inspections here and I don't want to pollute the environment. Also, since I don't weld I'll have the cats installed by a shop that may require OBDII compliant units.
Eventually, if the opportunity occurs, I want to add forced induction. I want my upgraded exhaust system to be adequate for it. Therefore, I plan to install metallic core, OBDII compliant cats in the near future. Adding the requirement of small size to fit in the space available will significantly reduce the number of products to consider.
