- December 28, 2010
- Russell, Ontario (Ottawa area)
- 2023 Aviator Reserve 201A
- Callsign
- VE3
Your thread was merged with this existing one found with the Search feature. There are 4 moonroof drains and depending upon which ones are clogged, water will pool in either the front or 2nd row footwells.2012 with Dual Panel Moonroof and Factory Roof Rails, 130k
I have a leak. About 70% of rain events cause the leak. The water drips from the driver and sometimes passenger center overhead lights. Recently, after a 10 hour rain event the water must have gotten behind the center console bc the hazard lights were flashing on their own and pushing the button couldn't turn them off. Even disconecting and reconnecting the battery didn't work. I assume the button was "stuck" or maybe shorting out because it got wet. A friend attached a reader and the hazards came up as a fault and then button worked soon after. I assume because it dried out. My A/C button also doesn't work now. I can only turn on the AC via the touch screen.
I cleaned out the two drain holes in the dual panel moonroof. The passenger side was clogged so i thought that would resolve the issue. Nope. After a light rain water was in the lights again. Turning sharp forcing the water out of them.
1. Are there other drain holes besides the two up front?
2. Where else could the leak come from?
Side note. I've had a leak in the back for years. Water drips down the third row seatbelt. Is that water entering from a different spot?
I wouldn't care so much but now that i see electronics can be damaged i am getting worried.
Thank you!
As for the water running down the 3rd row seat belt, that has also been discussed before. Chances are it is leaking from the roof rail anchor point. Have you checked the spare tire well for water?
See Water Leak
