- December 28, 2010
- Russell, Ontario (Ottawa area)
- 2025 Aviator Reserve 201A
- Callsign
- VE3... grid FN25hg
I don't recall anyone with a failure mentioning a 'noise' before it went. Many had no warning at all and a few noticed coolant coming from the weep hole.Does the water pump make a noise when failing? Heard a bearing like noise upon startup this morning. Only made noise when in R or P. Noise went away after a couple minutes. Definitely was coming from passanger side front, where the WP is. Alternator is right there as well.
Was a dreadful noise, but no issue with temp running hot.
Thoughts?
