94Eddie
- September 18, 2003
- 2010 Mountaineer Premier
I am assuming you have the 3.5L V6 engine. If so, it is very likely that the water pump has failed. When this occurs coolant will be dumped into the oil pan. Sometimes the engine can be salvaged if it wasn't run very long with coolant in the oil. Many times it destroys the engine and it will need to be replaced. I would be very surprised if you have a head gasket failure because the 3.5L V6 is a very stout engine other than the water pump issue. I would also question the capability of the repair guy if he did not consider a water pump failure. This is a well known issue with the version of this engine installed transversely in Ford cars and SUVs. The engine needs to be inspected to determine the amount of damage it has encountered.
How long did you drive the vehicle once you knew there was a problem? Did it overheat? How much coolant got into the oil? Unfortunately you are far from the first person to have this issues. There was a class action suit against Ford for this problem but the judge mostly ruled in Ford's favor. There is a long thread in the 5th Gen forum about this very failure. A lot of the 5th gen Explorers are getting older and worth less every year which makes spending money on a repair this expensive questionable. I call this "repair totaled" because putting $6k-$8k into a repair on a high mileage vehicle isn't always the thing to do. Personally, I wouldn't do it. I have the same looming issue with my wife's 2015 Edge. It has the 3.5L V6 used in Explorers and is about to reach 100k miles. Our dilemma is to sell it now that it is out of warranty, do a pre-emptive water pump replacement for $1.5-$2k or roll the dice and keep driving it knowing the risks of doing so. The good thing is that other than the water pump issue the 3.5L V6 is basically bulletproof which makes doing a pre-emtive water pump replacement a good option to consider.
One option I would consider in your situation is to buy a good condition used 3.5L from an Explorer in a salvage yard. Then change the water pump, timing chains and guides before installing it. This should bring the costs down quite a bit.
