tiedyed8
- July 19, 2009
- Macon, GA
- 1991 XLT
Ok--I replaced the rear cable regulator and motor on drivers side rear door with the newer gear driven. The window goes up and down great when using the rear switch. When you use the front switch, it works great up and down---unless you go all the way down. Then the window will not go up with front switch--it will still go up fine using the rear switch. It is weird--works fine using front until you go all the way down. When all the way down, the lights dim when you hit the front switch. Then it blew the power window fuse. Any suggestions would be greatly appreciated. Thanks!
