tydaug
- February 28, 2010
- Appomattox, VA
- '92 Explorer
I bought a '92 explorer. I was told the clutch went out. I got in and tried to shift, and there was no pressure on the clutch and it wouldn't go into gear without grinding. OK. So i came back a week later to tow it and found out the brakes and parking brake are not working. Both mashing to the floor like the clutch pedal did.
Went to the store and poured brake fluid into the empty resevoir. Still no brakes. (Clutch fluid has been good the whole time)
So now I'm thinking someone messed up the rear brake caliper when changing the pads and the fluid probably leaked out. (since the parking brake didn't work. I've seen it before)
So i called to have it towed and went back to the truck to meet the guy to tow it. On a whim I started it up and tried putting it in gear. FLAWLESS.
OK. I drove a little bit and tested the brakes. They work FLAWLESS.
I will take the drums off and check the rear brakes when I get a chance this coming week.
Any explanations????? Is there some safety mechanism that doesn't let you put the trans into gear if there is no pressure for the brakes? (That doesn't even make sense)
What do you think?
What do you think?
