what is my tow capacity | Ford Explorer Forums
pbguy420
hey guys, ive been doing google searches and calling ford dealerships and for some reason cannot find info on this subject because my 96 is so old. ive got a 96 sport 2wd.... axle code 41 if it matters, no manual. what is the damn towing capacity of this vehicle? im trying to buy a boat and want to know if im going to have to buy a new truck as well.
GCWR (gross combined weigh rating) starting on page "284" of the 96 Explorer manual which can be downloaded from Ford Fleet:
Dead Link Removed
There is an entire section of explorerforum dedicated to towing. Recommend you browse through it.
41 — 3.27 non-limited slip (Explorer/Mountaineer) is 2000 pounds max. Check the owners manual & your door sticker to verify. The real question will be how heavy is the boat, how far you intend to pull it, and road condition & grade.
The minimum items you will need are a trailer light wiring kit and a receiver hitch (bumper okay for small jon boat but not for anything heavy). Since its a sport with soft monoleafs, you may also want an inexpensive leaf helper or the ride will be soft and sway a lot with any kind of weight behind you. Also, be sure you tow with overdrive turned off.
